It bolts to the fuel pump, like I said above. All barbed fittings and rubber hoses.
One is suction and the smaller the return. The upper line is my gas tank vent, it'll connect to the breather on the valve cover. Get it??
Gary: Can you post a picture of the lines hooked up in the engine compartment? Ill be doing that part soon. I only have 2 lines under my hood(if my mind serves me right) with new stainless. My car is a 71 RR.
