If so a 600cfm 1405 eddie on a victorjr340 manifold with a air gap and eddie heads with no heat risers. It's perfect for the desert as it turns out.
No
I havnt seen your other post . Why do you think you are getting vapor lock ? Can it be heat soak instead?
Already I see 1 problem. You are running a fuel pump that puts out to much pressure for a carbed fuel system. 5PSI is the max for a Holley and E Brokes about 4 PSI is max.
