So if the burst panels are only a part solution, on your rat manifold, why not just mount the entire top panel spring loaded with similar bolts as burst panels, or would preventing linkage wide open throttle bind be too much of an issue/c concern?
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
