Another option that I don't think has been mentioned in this thread is the use of a double pole / 4 terminal cutoff switch like a Longacre 45780 or 45782 (for higher output alternators). It solves the problems of a constantly "hot" alternator wire / solenoid drain.
http://www.longacreracing.com/products.a...amp;prodid=7581
Decent solution. It is more money than a CD and 180 amp master switch
