This looks easier for my application.............Figured instead of a bar goig across from frame to frame I`d weld a plate w/a stud but that also limits any up or down shock adjustments..........
In a coil over type(or even a non coil over type) we normally do any shock adjusting at the bottom to change the body height but then you would have to get rid of the stud mount on the bottom... this pic shows the bottom shock mount(I use the long bracket then once I set the body height to the proper location with the shock travel correct, I cut off the extra length of the bottom bracket)
