11secdart weighs 3150 lbs with me in it, with the current 363 W2 headed small block with a 590 lift mechanical cam, 904, and Ultimate prepped 4700 stall 8 inch convertor with 4.56s thru mufflers its gone a best of 10.40 at 126 with a 1.40 60ft.,the last 5 years or so its been run an a throttle stop running 11.50s at 114 with low 1.50 60fts. It isn`t driven on the street but could be with a few changes, my friends try to convince me too. I have a new 408 stroker with W2 heads in the works to run on pump gas and hope to have it finished for next season.
