Race weight is +/- 5235 lbs depending on how much fuel is in the tank. Truck is an 05 Dodge Ram 4x4. Only thing not factory is the engine, induction, trans and CalTrac's. Run's on 91 pump, 14 mpg highway. Best 1/8 to date is 6.87 @ 98. Best 1/4 with the brick is 11.03 @ 118. 60' between 1.48-1.50 in 4WD. Yes I race it in 4WD cause it's the only way I can get it to hook.
