I wouldn't trust a comp test until after I had run it and the lifters had a chance to settle in with the new adjustments. Right now you do not know if number 7 was mis-adjusted to begin with or if you have more serious problems afoot. Pulling that lifter is the only way to know now.
Master, again and still
