I have a 471 Hemi with alum heads and a hydraulic cam. I have been hearing what sounds like a lifter or valve train tick back in the #5 or 7 cylinder area. I just did a compression test and came up with this:
#1 - 190 : 190 - #2
#3 - 190 : 190 - #4
#5 - 190 : 195 - #6
#7 - 175 : 185 - #8
So I pulled the driver side valve cover, major PITA with power brakes
![](/ubbthreads/images/graemlins/flame.gif)
Nothing looks terribly loose or out of wack. You can push down slightly on the lifter to cause it to be loose but I am guessing that is just the hydraulic part. I have messed with hydraulic in a long time as my other motor is solid roller, way easier to adjust. Always seems like I am guessing on hydraulic, any tips.
Plugs are also looking rich, but strangely the #7 that is low on compression is one of the better looking plugs.
