Jeff are you going to run both the giggle juice and your meth injection?
yes unless I hear it's not a good idea. and it's meth/water, (washer fluid) not straight meth
Not stating this from my own experience as I've never played with nitrous, just what I've read/heard, but it should allow you to not have to pull as much timing (if any), but I'd be careful and retard it plenty to be safe. I just thought I'd mention it since it may be something of importance to someone helping you out with the fuel system.
Make sure you buy the cheap washer fluid that doesn't have the other junk mixed in. IMO you'd be safer with a true 50/50 mix of meth and water though.
Now I need to pin those needles, got to feel that heat Hear my motor screamin while I'm tearin up the street
