Quote: Not sure why you think it is turning the tires for 60ft. Highly unlikely on drag radials. Like I said earlier, they are hooked or not and generally they slip at all, they spin hard.
Watching the video, the car looks way too loose in the front to me. It stretches the front end completely out real early and then sets the front end right back down, which will unload the rear
Monte
My 60ft times are way off and I have a racepak system. It shows the drive shaft rpm. The car is hooking at the hit of the throttle but then is spinning more than it should.
Put up a screen shot of a graph where you think it is spinning
