Quote: Did you get some rubber boots/thingys to run the wires between the door and jamb area ?
I got and tried a few different styles when I was putting power windows in the my Torana. I might still have some of the smaller diameter ones around as I needed room for the power window wires as well as power locks as well.
I need to check the kit
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
