Quote: It won't be going anywhere. I am going the old beer keg in the bed route. The stock location for the tank can be problematic for dual exhaust (somewhat the same layout as the under bed tanks on the 70s D100s).
I figured that was the case, if I end up making a tank that fits under the bed behind the axle, we might want to make one for you at the same time if you want to go that route, I calculated I can make a 16 gallon tank yet still leave room for airbag/4 link suspension
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
