Quote: I have the original fuel tank from my 37 Dodge PU that should be the same as what was original to your truck. I believe it is still solid. You are welcome to it.
Mike,I might take you up on that offer, I'm not sure if a stock tank will work with the 302/auto and maybe that's why it's missing.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
