I got busy yesterday and didn't get the trial fit done till today.
The fit was pretty much what I expected, really close on the outer fender lip but room on the inside by the leaf springs.
If I roll the fender lips they'd probably clear okay.
They should clear fine after I install the dana since it's narrower.
Here are the pics.
They might be kinda big, but I figured it would show the detail better.
On a side note one complaint about the Summit wheels would be that the lug nut holes could be a little larger for fitting a socket in them.
A thin wall chrome socket is a tight fit and drags and binds up while just running the lug nuts snug.
I tried 2 different thin wall sockets and one fit better, but both are a tight fit.
Longer lug nuts would probably help.
