on a side note about rpm heads, does anyone know how fast these heads could push a b-body?
Also, if the heads were fully ported what is the ideal cubic inch for these heads? In other words what works well, and what is too big?
Not a B body but a Friends duster has gone 8.80's-8.90's with Edelbrock heads, solid lifter cam, and a tunnle-ram. App 500 ci.
what dos this car weigth
what carbs on the tunnelram
what solid cam
very nice combo
I won't post a weight or cam specs because I'm not sure. Its a Indy tunnel ram with (2) 750's. Now for the good part. He ported the heads himself (first attempt) under the guidance of Tom Hemphile. Not bad for a 23-24 year old. His Fathers 69 charger has gone 8.60's with B1-BS heads and an old weiand tunnel ram.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.42@138.27
