Quote: Can you get a single replacement stealth, provided you still have the other one? If not, then it all boils down to what floats your boat. Unless you change a number of things in the combo, low speed torque (launch, traction) won't change much. A bigger port will add more to the upper rpm range, but not too much to the lower rpm range.
.. Or just a pair of bare Stealth heads and put your stuff in them..
Another thought, aren't Indy EZ's were a direct bolt on.. Do they come in a M/W port.?? That might be a thought as well..
