so now kent is going to build a motor .. Now he told me that there are a hole bunch of them running all ready guess not. as for the build I hope this is to really iron out some of these major problems. not just some smoke and mirrors. used to take advantage of more mopar folk
I am doing the build. I am doing this to show that all is not gloom and doom with these blocks. They are out there running now. Some pretty nasty dirt cars are using them.
the first block I got from kent the lifter holes were off by 1/4in and the oil galley in the cam tunnel broke through . it came with epoxy in two other oil passages tell how will you fix these little problems the head blots and thurts are easy : ![](/ubbthreads/images/graemlins/popcrn.gif)
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
