Having had a car with a low buck RB, and another with a W5 416, (both high 9sec combo's) starting from ground zero you will have a cheaper less stressed combo from the big block. That's a no brainer.... but since you already have the 408 (not sure of the combo) you might be ahead of the game to stick to it and make some improvements. Going big block will also end up with a trans change, and more than likely a new torque converter purchase which will factor into the cost of the build.
Our big block is gone... and we're sticking with the small block. Not sure why....but we prefer it that way
He has Indy heads a roller and good trans and convertor. I think with a few tweaks he can get where he want to.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
