Are all five wires in the connector & attached to the switch? Like I stated earlier the yellow is power for each of the three non master switches, all original grounding is done throught the master & a ring connector on the drivers "A" pillar...So for any window to work the master has to be plugged in & the single switch to that location has to be plugged in..If you run the window from the master power is supplied by the tan wire...
Randy - maybe this is where I've "seen the light"... on that passenger door I was removing the original harness as I was putting in the relays. I now see exactly what you're saying, I'll put it back together in the morning and update the post. I had gotten it in my head that this was replacing the factory harness, instead of just getting rid of the current draw.
Darren
