Quote:You just looking for a original type ride with crisper handling?Maybe just R/T 440/Hemi T-bars, front sway bar, and front end aligned for 2-3 degrees positive caster. See if you like that. Then it's an easy bolt on for Bilstein RCD shocks.The stiffer the front T-bars, less weigh transfer lauching the car at the drag strip. Same with the handling shocks.
