You've got the right ideas so far, start with your bushings and ball joints make sure they are in order, then move into a set of Bilseins or the QA1 s if you like the upgrade your swaybars, Just keep in mind what your plans are for the Charger, do lots of reasearch and stick with your plan, no need to go all out for a nice cruiser, most times a set of good shocks and a little maintenance will make you a happy cruiser.
As for your front torsion bars lots of options from PST or Firm Feel ,Mancini ,Hotchkis , A 1" diameter bar will give you a nice ride withe the bilsteins, your superstocker rear leafs may be a bit much for a cruiser but upgrading your front torsions and shocks will definatly change the ride quality. Leaf Options again from firm feel ,pst , mancini,hotchkis, that rear end ratio is nice on the track but as a cruiser id opt for a gear vendor overdrive or take it down to a 3.55 ratio just to settle the engine down a bit.
Good luck
Ron
