- The Low/Reverse band is in the back of the case - It's only used in "Break-a-way first" (meaning standard valve body manually shifted and held in "1")
Nope, breakaway is 1st gear in the D position...the rear band is not applied in breakaway, it is applied in manual 1st. Breakaway is when the sprag is most susceptible to harm under power.
The Forward clutch is actually the rearmost clutch in the geartrain - but it's applied in all forward gears, hence the name.
The term "forward clutch" is GM/Ford, Mopar simply calls it the rear clutch which I prefer because "forward" implies to the front and it confuses novices.
The INTERNET, the MISinformation superhighway
