The plan should be to keep as much OE metal as possible in a true restoration. Sometimes, it isn't really feasible though. The rust in the trunk floor ribs is typical and once it is media blasted, there will be hundreds of little pinholes. Instead of replacing the full floor with China tin, try and just use the center section and butt weld it in, that way, the OE spot welds will still be retained.
