I definitely would not do the square pattern, it would look unfinished like you forgot to install the collector or something.
Since the car has a blower you could get away with the flat pattern zoomies but you will never be able to put mufflers on it in the future, so as long as you're ok with that you should be fine.
Yep ... if its a street car... thats gonna
be hard for exhaust
