Rick if you don't find anything after you get everything cleaned up and put back together bring it up to temperature and dump in a can of K&W block sealers. Should be able to get it at your local auto parts or they can order it in for you. That stuff works great and if I remember right it even has a water pump lube in it.
I might just try this next.....too save a bunch of work (I'm Lazy.....lol) Thanks
