PLEASE HELP ME DIAGNOSE THIS ....???????
#1370336
01/15/13 03:26 PM
01/15/13 03:26 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Hoping it's a simple fix on the SM-BLK 408....#1 Cylinder Exhaust roller is picking up some moisture is my guess....I know the header bolt hits into the water and I sealed it.....does the rocker shaft bolt also hit water...???? It seems to be very minor leakage and no discoloration in either the oil or radiator...???? Engine has only had run time on the stand.... Thanks in advance ![](/ubbthreads/images/graemlins/wink.gif) Rickster
Re: PLEASE HELP ME DIAGNOSE THIS ....???????
[Re: rickstershemi]
#1370337
01/15/13 03:30 PM
01/15/13 03:30 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Is this rocker directly under the evac breather? Iv'e seen that from condensation directly over the evac breather, If the breather has moisture could be there. ![](/ubbthreads/images/graemlins/Twocents.gif)
Founder and CEO of the Central Valley Mopar Drag Pack
[Re: mikeysmopars]
#1370338
01/15/13 03:35 PM
01/15/13 03:35 PM
rickstershemi
The breather is above #3 intake and exhaust with no indication of moisture....that was acually my first thought ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
These are J-Heads that have had some extensive work & milling as well...????
[Re: rickstershemi]
#1370340
01/15/13 03:46 PM
01/15/13 03:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If they broke through on the port and any water went back into the engine all of the rockers would have the same color oil... how much run time has it had and at what temp... lets see the inside of the VC EDIT The rocker hold down bolts dont go into the water ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1370341
01/15/13 03:55 PM
01/15/13 03:55 PM
rickstershemi
My thoughts as well Mike on knicking the port....the engine has been run numerous time on the stand and brought well up to temp.....the valve cover does have a baffle underneath the breather....but I never took into consideration the width of the baffle...???? The motor does tilt to the rear....I set it up on the run-in stand as it would sit in the engine compartment as close as possible...????
[Re: rickstershemi]
#1370342
01/15/13 03:59 PM
01/15/13 03:59 PM
MR_P_BODY
Well if the baffle is leaning towards the front it can run the condensation off that direction(it may not be level with the engine) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: rickstershemi]
#1370343
01/15/13 04:02 PM
01/15/13 04:02 PM
MR_P_BODY
Also are you running E-vacs with a open breather... that tends to draw in more air (with moisture) and dumps the moisture on the baffle ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1370344
01/15/13 04:07 PM
01/15/13 04:07 PM
rickstershemi
Just a PVC to the Intake on the odd bank....the baffle is definately running down hill away from #1
[Re: MR_P_BODY]
#1370349
01/15/13 06:44 PM
01/15/13 06:44 PM
rickstershemi
I thinks its still a condensation problem but I dont understand why its on just the #1 rockers.. by the way what is that oil.. looks like it was run through a bucket of rust... I would pull that rocker shaft just to verify it isnt some weird thing like the hold down bolt but in the stock heads the pedestal and the bolt are well above the water... if you were to break off the pedestal the bolt doesnt even go to the bottom of the pedestal... use one of those radiator pressure testers and pump up your radiator with that shaft off
The oil is clean (VR1 10w30).....just looks wierd in the pic....the rust is just on the #1 Exhaust Rocker....no pitting on any of the parts....wipes right off....can't be a huge problem due to no contamination in either the oil or radiator....but would like to get to the btm of this...???? I will pull the rocker shaft and see if anything looks unusual ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: pittsburghracer]
#1370351
01/15/13 06:48 PM
01/15/13 06:48 PM
rickstershemi
Rick if you don't find anything after you get everything cleaned up and put back together bring it up to temperature and dump in a can of K&W block sealers. Should be able to get it at your local auto parts or they can order it in for you. That stuff works great and if I remember right it even has a water pump lube in it.
I might just try this next.....too save a bunch of work (I'm Lazy.....lol) Thanks ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: rickstershemi]
#1370352
01/15/13 07:47 PM
01/15/13 07:47 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
Just because the parts are new doesnt mean that there couldnt be rust in the rocker shaft. coolant left over from teh grind process could be the culprate (rusting the inside of the shaft) Good place to look none the less.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#1370353
01/15/13 08:33 PM
01/15/13 08:33 PM
rickstershemi
In just one rocker.....I really don't see how, plus I personally inspected all the ne components that went into this build.
