Just a PVC to the Intake on the odd bank....the baffle is definately running down hill away from #1
I thinks its still a condensation problem but I
dont understand why its on just the #1 rockers..
by the way what is that oil.. looks like it was run
through a bucket of rust... I would pull that rocker
shaft just to verify it isnt some weird thing like
the hold down bolt but in the stock heads the pedestal
and the bolt are well above the water... if you were
to break off the pedestal the bolt doesnt even go
to the bottom of the pedestal... use one of those
radiator pressure testers and pump up your radiator
with that shaft off
The oil is clean (VR1 10w30).....just looks wierd in the pic....the rust is just on the #1 Exhaust Rocker....no pitting on any of the parts....wipes right off....can't be a huge problem due to no contamination in either the oil or radiator....but would like to get to the btm of this...???? I will pull the rocker shaft and see if anything looks unusual
