Quote: Is this rocker directly under the evac breather? Iv'e seen that from condensation directly over the evac breather, If the breather has moisture could be there.
The breather is above #3 intake and exhaust with no indication of moisture....that was acually my first thought
These are J-Heads that have had some extensive work & milling as well...????
