If they broke through on the port and any water went
back into the engine all of the rockers would have
the same color oil... how much run time has it had
and at what temp... lets see the inside of the VC
EDIT
The rocker hold down bolts dont go into the water
My thoughts as well Mike on knicking the port....the engine has been run numerous time on the stand and brought well up to temp.....the valve cover does have a baffle underneath the breather....but I never took into consideration the width of the baffle...???? The motor does tilt to the rear....I set it up on the run-in stand as it would sit in the engine compartment as close as possible...????
