The best thing about my G.E.R. was when someone stole it from my shop when the transmission that it destroyed was being rebuilt. As others have said run away as fast and as far as you can!
Digger73
If all the other conv. manuf. charge %700 for a good t-brake conv. and GER charges $350, there must be a reason.
I have had 8" JW & 8" ATI @ 630 to 760 HP and NO problems with either. They cost about the same.
You GET what you Pay for!
I learned a long time ago that its less expensive to buy a quality part, than to replace a cheap part 2-3 times.
Don
