The NAPA or whomever bearing is supposed to come with a shim to make up the difference, but still don't use it. BRC usually makes a run of these original SG8 bearings every 12-18 months because they are used in other applications. According to Chris they should be tooling up in a few months but nothing is etched in stone.
