OD is 90mm. For SG, Go look it up it is in the 307 or 308 spec from MRC or SKF. I was just trying to clarify why it is a special 308. It matches the 307 except for OD. In my opinion this is not something you want to start shimming. Use the correct bearing and selective snap ring.
