Re: SB: What heads??
[Re: Triple Threat]
#1357673
12/23/12 05:44 PM
12/23/12 05:44 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Brian can you share the flow numbers on those -1's? Did they start as 245's?
I can, but I won't have them until Wed. as we are closed mon. and tues. They topped out at .750 lift at 360 something, and stayed there, did not lose flow after that up to 1". At .500 I believe they were 316 or 318. I used a 2.125 x 5/16 intake valve, angle milled them down, our valve job, some short turn work, slight bowl work and chamber work. This was a 245cnc intake port, but I did the ex. port and chamber myself. I don't like Indy's ex. port and chamber at all.
Brian Hafliger
