....The shift forks are OK but I would chop off the nub and install them in a good ball/detent cover from an early 833. Gus
Is this gouge ok?
If it were my tranny i'd get new forks
another vote for Jamie Passon - you could email him the pix and get some more feedback
Those are the stock steel forks, I would use them I did a older 2.66 box for a customer several years back, I sent his gears to Liberty to have them replace the engagemnet teeth ring,and they converted them to Pro Shift I called them back and ask why did they do that instead of replacing the rings with stock ones, thier explanation was that stock ones aren't availble. I had told them that this box was a street box, not a race box He siad put it together and drive it and then call them back, it would work fine It DID
