Is it a cast iron case or Aluminimum? I cant remember when they quit using the 833 and went to the 0D833.. The little teeth that match to the little teeth on the syncros are what you need to look for. If they are runded they need replaced. If the hace clean edges they are good to go.
It's an iron case. I think by my gear counts, it's a close ratio 2.47/1.77/1.34/1.00 gears ??
What does excellent, acceptable, and bad rounded teeth look like?
Do I need better pictures of the teeth??
