now same deal except you run power from alternator to starter relay then into car instead or in through and back out stock
Since I have my battery in the trunk it's alt to battery then through cut off switch to starter relay and in leaving all stock wires in place but wire that would have gone to back bolt on alternator is cut short and taped in case one ever wanted to go back stock.
