Quote: I just went to Costco and they had a 3.25 ton without the jack stands for $105. A little much for me. I'm going to head out to Harbor Freight later today and probably pick everything up.
Just a quick question with regards to brake fluid. I've got some dot 3 in my cabinets, but I opened it about 2-3 months ago to fill up the brake fluid in another car. Is it still good? I heard they go bad quickly due to their ability to absorb moisture or something.
Good enough for what you are doing to fill up the empty master to see what is wrong.
You will end up replacing the master and/or wheel cylinders very soon. Like immediately. So don't sweat the open brake fluid container. It's NOT a humongous deal anyway.
