Oops, I forgot to mention the three middle bolts were ground to reduce the diameter for oil flow through the T&D rocker shafts. The T&D rocker shaft has very thick walls, ans if you use a bolt or stud that is not reduced in diameter where it goes through the shaft, it will cut off oil flow to the rockers.
