Thanks, I think I will try that to remove the heli-coils. When I broke the first stand, I converted the heads to use the max wedge style hold downs that are a block with a hole machined in them for the shaft, so the circular part of the stands on the heads was milled flat. I will have to get some photos this weekend. It's easier to show than explain.
