The mounting block that is pressed onto the water pump shaft can be set at different depths, obviously yours is out too far. You may need to play around with it a bit but you should be able to mount that fan w no issues.
If this were the case then he would have an issue I would think with BELT ALIGNMENT ...
Yes and no. He hasn't posted any pics, so it's hard to comment further, but a simple tweak on the press and maybe a wp pulley swap and he should be fine, but if it's the mopar fan there is no reason for it not to work. A lot can change on a car in 40+ years. The flat AC pulley should pick up a ton of room for you and they're easy to find.
