Also, I would say that the relationship of the fan blade to the shroud is more important than the clutch face to the radiator (if greater than 1/4 inch, less is a big deal as the engine will rock on the mounts, esp with a stick). Seating the fan at the proper distance in relation to the shroud opening will help to guarantee good air flow.
