When you are doing all of that don't forget to also check the angle of your rear spring shackles drivers side needs to be @ the 10:00 and the passenger side @ the 2:00 o clock position.
Mine basically go straight up. I do have another set of mounting holes that are at about 10:00 and 2:00.
Move the upper mount forward so you get a good angle (I like at least 30 degrees forward from the spring to the upper shackle mount ) sitting still with the chassis loaded.
