If originality is not an issue and you still think you have ignition trouble why not use an aftermarket ignition?I use msd in everything hard to go wrong with multiple sparks with a lot of juice behind them.I have also had the side benefit of it "hiding" a poorly tuned carb,unless that carb is literally pouring fuel down your intake it will fire.
