just tried to start it again after a few days and still wont start. in 'run' i have 4.5 volts at the coil, if i bypass the ballast and run a jumper i have 7 volts at the coil, at the ballast i have 10 volts, and the battery has 12.5 volts..i dont know if thats not enough juice at the coil but thats the way its always been and runs just fine, just a b..ch to start after it sets for a while..
