Quote: I was surprised to see a full oil pan instead of a dry sump system!
Danny
The pan does look pretty darn big!!
The thing is the block isn't a skirted block. So the Pan goes around the crank much like the newer pro stock stuff or GM stuff. It also has a big kick out on the side with a bunch of baffles and crap inside to get the oil out quick.
It has a 5 stage R&R dry sump pump. 3 stages sucking from the pan and one stage "T" ed off going to each head sucking oil from them.
