Re: 11/16 tie rod upgrade, what are the benefits?
[Re: Kern Dog]
#1190311
03/05/12 11:12 AM
03/05/12 11:12 AM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
What did the trans-am and NASCAR guys run bak in the day?
Herein lies some of the problem; These two venues were considered contact sports, therefore increasingly heavy duty parts became required to allow the cars to finish races. Since these were the most practical handling applications of the era, many assume duplicating their configurations are the best means of skinning the cat these days and similarly install heavy duty parts where they may not necessarily be required. Nascar guys also use 3/4 and 1 ton full floater truck rear ends with oil coolers. That's probably overkill for a street app as well.
It may have been in one of the above posts, but here goes: Are the C body tie rod ends the same size as the A, B and E cars? If not, I guess to use the 11/16" units, you'd need 2 inners, 2 outers along with the sleeves? Is the taper in the center link and lower ball joints are the same degree as the other cars?
Same size in what regard? The threaded shank on small units standard tie rods is 9/16, the large C body units are 11/16. So yes, to covnert you need two inners, two outers, and two adjusting sleeves. The taper fit is identical betwen the two sizes.
Entire Thread
NV69B7RR
03/03/12 06:08 PM
Kern Dog
03/03/12 07:14 PM
Daty Rogers
03/03/12 07:25 PM
TC@HP2
03/03/12 07:38 PM
Mattax
03/03/12 08:46 PM
72Swinger
03/03/12 09:22 PM
AndyF
03/03/12 08:10 PM
jcc
03/04/12 03:54 AM
feets
03/04/12 05:01 AM
ahy
03/04/12 06:37 AM
jcc
03/04/12 12:25 PM
340duster340
03/04/12 02:26 PM
ThermoQuad
03/04/12 06:23 PM
340duster340
03/05/12 03:34 AM
jcc
03/05/12 01:17 AM
autoxcuda
03/05/12 05:25 PM
Supercuda
03/06/12 12:28 AM
Aero426
03/06/12 04:31 AM
72Swinger
03/06/12 04:38 AM
340duster340
03/06/12 03:32 AM
docford
01/28/17 02:54 PM
jcc
03/05/12 01:38 AM
jcc
03/05/12 01:50 AM
Rick_Ehrenberg
03/05/12 05:18 AM
JF_Moparts
03/05/12 05:36 AM
Kern Dog
03/05/12 08:15 AM
TC@HP2
03/05/12 03:12 PM
03/06/12 06:43 AM
Pale_Roader
03/06/12 10:52 AM
Supercuda
03/07/12 12:56 AM
Pale_Roader
03/07/12 01:43 AM
geo.
01/31/17 04:06 AM
jcc
01/31/17 05:48 PM
Kern Dog
06/29/22 05:47 AM
JP8
06/29/22 02:26 PM
AndyF
06/29/22 05:27 PM
Kern Dog
06/30/22 12:45 AM
AndyF
07/01/22 02:12 PM
moparx
07/01/22 04:55 PM
Sniper
07/01/22 10:04 PM
ThermoQuad
07/02/22 10:43 AM
83hurstguy
12/15/22 01:57 AM
moparx
12/15/22 07:57 PM
83hurstguy
12/16/22 01:28 AM
moparx
12/16/22 05:27 PM
375inStroke
12/29/22 04:40 AM
jcc
01/23/23 05:19 AM
jcc
03/20/23 04:31 PM
moparx
03/20/23 07:24 PM
jcc
03/20/23 09:25 PM
autoxcuda
03/21/23 05:47 PM
IMGTX
03/22/23 01:17 AM
Sniper
03/22/23 02:26 PM
autoxcuda
03/24/23 06:43 AM
Sniper
03/24/23 11:08 AM
375inStroke
12/29/22 04:42 AM
GY3
01/03/23 10:29 PM
Mopar Mitch
07/01/22 06:28 PM
AndyF
07/01/22 08:57 PM
astjp2
07/05/22 09:18 PM
olwhite64
12/12/22 05:15 PM
AndyF
12/13/22 02:46 AM
TC@HP2
01/28/17 11:08 PM
Supercuda
01/29/17 12:02 AM
