It may have been in one of the above posts, but here goes: Are the C body tie rod ends the same size as the A, B and E cars? If not, I guess to use the 11/16" units, you'd need 2 inners, 2 outers along with the sleeves? Is the taper in the center link and lower ball joints are the same degree as the other cars?
