I had a RT lobe grind for awhile. There seems to be mixed opinions on the durability issue with valvetrain parts with the RT lobe. One guy at Comp told me it was OK to use on the street, the consenus among others is that it will be a parts breaker in a street/high mileage ap.....By the specs I would think its fairly gnarly and probably not the easiest on parts. I know Smothers had a RT lobe in a stock appearing Bee that ran very hard...but he said it wasnt useable on the street...due to being a parts beater.
I was told (not by Comp, but somebody way more knowledgeable) the HT 420 lobes are supposed to be easy on parts...
Give Porter a call...He knows the Comp lobes.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
