I am thinking of pulling the front engine harness out of the car and inspecting all of the connections. Then tape it back together after replacing as much of the blue wire that I can find. Then retape it back into a harness again once I am sure that it is in good shape.
I am also going to check the green wire going from the VR to the alternator for any resistance.
Thank you all for your help.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
